- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
HI VAIOS !!! I bought my VAIO few days ago, and i had to change the Win 7, becouse It was in Italian (witch I dont speak). So than i noticed that brightness controll (FN+f5, FN+f6) and padlock (FN+ f7) doesnt work. I installed the new drives and nothing. I googled the problem and it says that i am not the only one with that problem, withc realy made me happy :), but yet i couldnt find the right answer of the problem. Now PLEASE, if anyone of you had the same problem please help me fix this frustrating problem.
Thanks,
Ivan
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
To get the Fn Keys working try installing the following Utilities IN ORDER: -
1. Sony Shared Library
2. Setting Utility Series
3. Vaio Event Service
4.SFEP
You can download these from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VPCEB2M1E_WI
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Ivan,
Have you reinstalled all the Sony Utilities? Which keyboard driver are you using?
Exactly which Vaio model do you have and which version of Windows 7 have you installed?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey!
Thanks for the responce. I installed win7 ultimate and i installed graphics driver, cause the screen looked a litle bit squery (a tiny little squares are seen, wich makes the picture not crystal clean, so i dont know if this is what its spouse to be). I couldn't find specific keyboard drivers, and have no idea what drivers should i install, cause everything seems to be working ok ( except maybe fot the squery screen ).
My notebook model is VPCEB2M1E/WI
Thanks ALOT for your time!
Ivan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
4.SFEP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks, I'll try this and tell if works.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
IT WORKS!!! THANKS FOR HELP!!! I OWE YOU A DRINK !!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'll hold you to that if we ever meet!!!!!
Pleased you have sorted the problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Great advice. These instructions sorted out the same problem (of losing brightness control from the Fn keys) after installing Windows 10 on an older Vaio (VPCCW). Thank YOU. I ended up not following the order though, although it still worked, so perhaps order is not critical (or at least, wasn't so in my case).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I recently installed Windows 10 64 bit on my Sony Vaio. Brightness and other controls stopped working. I have made a set of files that need to be downloaded and installed in order for your function keys to start working again. Download and install these files from my Dropbox.
https://www.dropbox.com/sh/72wmmvbaqoxo0e9/AAD1nXtM2Q54Qf1NkDdrLeEpa?dl=0
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
VPCCW model VAIO
Thanks again!
Sincerely,
Robin Watson
Sent from Mail for Windows 10
