- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Problem with SMP-N100 affecting recording?
I have a RDR-HXD1070 connected to a KDL-40X3500 which works fine no problem. However I recently connected a SMP-N100 to the KDL-40X3500 and now sometimes the RDR-HXD1070 fails to timer record.
Both devices are connected via HDMI cable to the KDL-40X3500.
If I am using the SMP-N100 and there is a timer recording due on the RDR-HXD1070 the device shows timer standby and then when the time arrives to start recording it just says timer cancelled and turns off.
If I am not using the SMP-N100 the RDR-HXD1070 records no problem.
So is the SMP-N100 affecting the RDR-HXD1070 or is it just coincidence?
Also both devices have been updated to the latest firmware available.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Gut instinct is that its coindidental as the two don't have any need to interact as far as I'm aware. But if you've left it off for a couple of weeks with no problem and then connect it and it keeps happening constantly, then somethings not right, but very strange...
Maybe try software/factory resetting all the devices including the TV as thats the constant here..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for your reply.
I have tried what you said regarding resetting all devices but to no avail.
I will however say that the SMP-N100 is connected to the Internet wirelessly and when using say the iPlayer and there is a timer recording coming up the RDR-HXD1070 won't record.
Now if I'm using the SMP-N100 with an USB stick plugged in and playing a movie off that and there is a timer recording coming up the RDR-HXD1070 records!
So what's going on????
It would appear the wireless signals are affecting the RDR-HXD1070 or is that just coincidence???
