how can I turn off the autodimming for KDL-32EX302 ?
SOLVED
profile.country.ro_RO.title
georgecoman2
Visitor
Hello,
I would apreciate so much if someone could help me to turn off the autodimming for a Sony Bravia KDL-32EX302 ? I asked for help several times to online support, no helpfull answer till now.
No results after firmware updates.
Many thanks,
George
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Hi George,
welcome to Questions & Answers..:smileyhappy:
Click Home on the TV remote to bring up i-Manual.
Select Settings
Then select Eco.
You should then see Light Sensor.
Turn this off should stop your picture brightness from autodimming..:smileywink:
6 REPLIES 6
Thalamus.
Champion
Hi George,
Select Settings
Then select Eco.
georgecoman2
Visitor
Hi Thalamus,
Thanks for help!  I don't remember for sure if I found this option (I'm not at home right now), but surely I've turned off all settings I've found, including Adv. Contrast Enhacer. But the autodimming persists (dark scenes becames darker, very annoying). It seems to be a tehnical issue, but the response from the service was 'there are no technical problems'. I think they should have know better than me to make settings :slight_smile:
Anyway, I will check again if Light Sensor could be turned off. If you know any other setings that could help, please help!
All the best!
George
profile.country.en_GB.title
Bravia55HX
Member
i did post some thoughts but it appears some idiot removed it!
Thalamus.
Champion
Bravia55HX923 wrote:
I didn't notice your post before I posted my reply..:smileyconfused:
Bravia55HX
Member
Thalamus,
its fine, i posted a couple of minutes after you and it was up but later found it had gone!
dont worry about it, probably a gremlin:smileywink:
Thalamus.
Champion
Thalamus,
Ah ok then..:smileyhappy:
