Looking for a stand so that I can utilise the TV in the middle of a room. The stand needs to lift the bottom edge of the TV at least 2 feet off the ground to easily view the picture.
Only found quite high industrial looking units. This is a home, so something simple and plain is likely to fit in ok.
Needs to be on wheels so you can pull the TV out when required. Black colour is fine.
Hi pato_londres,
Welcome to the community.
I'm just going to see what I can find out and get back to you. Someone else in the community might have some ideas until then.
Thanks,
Pascale
Hello pato_londres,
I see where you're coming from. I've never come across such a stand to be honest, but it may be available at local TV stores. I've tried to look up the Sony recommended stand for your TV model, It'd mainly look like this: https://www.sony.co.uk/electronics/support/res/manuals/4748/a04843eafe53590e7772e93b8e4391a9/4748642...
Vanilla_
