Xperia RAY restarting / reboot problem.
jagant11
My Xperia Ray Mobile is keep restarting, can any one here help me to fix it?
i bought it before 10 months. suddenly it started rebooting. Slightly_frowning_Face
i tried safe boot by holding the menu button when the sony text displayed, but it doesn't work. Slightly_frowning_Face
i tried connecting with PC companian, it is not detecting the phone. Crying_Face
when the phone is switched on "sony" text is blinking then "Xperia" text is displayed then
if i try safe boot it vibrates and restarts else it restarts silently. Angry_Face
Phone was not rooted and i didnt install any apps yesterday. Neutral_Face
Francis
Hi there.
Is possible that the issue is the Software.
For this I would recommend performing a Software repair.
go to this post for the instructions on performing the repair:
http://talk.sonymobile.com/message/316161#316161
Hope this helps.
Francis.
16 ANTWORTEN 16
Francis
Hi there.
Hope this helps.
Francis.
jagant11
Really thanks for your solution it works great.
i got my mobile running back fine.
is there any way to restore my contacts which were wiped while repair?
Thanks.
Jagadeesan
Devanand
Thanks a lot.. It resolved my Issue. Slightly_smiling_Face
Tags (1)
nishan01
If i connect to pc companion its shows Green light but its not connecting to the Pc companion.
Pls help me as quick as you can.
Krunalpatel1410
Hi All,
I have same problem like you mention above.
My phone is also restart by blutetootg "ON" operation.
Please, can any one provide detail steps to solve this issue.?  It will be very helpfull.
Thanks,
Krunal Patel
9428171284
pdjonandroid
Roboot loop solved.
As soon as it booted to the desktop I kept pressing the settings button until the settings menu popped up.  Once it did it stopped rebooting.  From here you can go to the program you think caused the problem or action that cause it and undo that action or force close the errant app.  If this fails then from here you can do a Factory reset.
Hint.  I took  out my SD card so the data on the SD card was safe.  When I got the phone reset I re-inserted the SD card again.  I was then able to re-install all my apps and contacts that were backed up to the SD card.
jinu
Many Thanks:smileyhappy:
It resolved my problem, but it took me some time to get the settings menu open.
So if it is happening with someone else, please keep trying opening settings menu.
It saved my contacts, accounts and all apps.
Thanks again pdjonandroid Waving_Hand
Jitendra
saikiran562
while dive software update it showing error 11,
please help me to getout of this issue.
Pavan_Koundinya
but my phone is still not rebooting.......
so please , anyone help me.....
