WhatsAPP problem...:(
SOLVED
Not applicable
I have a xperia pro...my gmail,facebook is working fine even navigation ,weather everything okay.
but when i try yo connect to whatsapp it says ..."check wheather you are connected to internet..."
i tried it many times but the pop up comes up everytime with this msg..
plz  help...:(
thanks in advance.
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.PH.title
MarlonUk1
you perform the clear data and reboot and check the app again if it works alright.
if it did not work, uninstall the app,
go to google play and search  the app again.
https://play.google.com/store/apps/details?id=com.whatsapp&feature=search_result#?t=W251bGwsMSwxLDEs...
9 REPLIES 9
MarlonUk1
try clearing the apps data. settings>apps>manage apps> look for the app and tap "clear data" reboot your phone
if that does not work, try reinstalling app
Not applicable
thanks for the replay..
bfore i clear data...or unistall whatsapp..and then reboot...
but 1 silly Question...
how do i install it again...i mean is the software s still dere in the phone or do i have to download it again and install it.??
MarlonUk1
Not applicable
thanks ..it worked...:smileyhappy:
MarlonUk1
what worked? the first or the second one?
sure, no probs Slightly_smiling_Face
Not applicable
i reinstalled it....and it worked..now i m chatting..:smileyhappy:..thru it..
archie1511
Visitor
I am also getting the same problem.. I reinstalled the app several times but every time it would pop up with the message
"unable to connect" though internet connection exists.. plz help.
BLOKK
Visitor
hey my whatsapp didn't send messages. so I uninstalled it, downloaded another and installed it. My chats were restored but my contacts aren't showing. when I refresh it says:"please try later". please help.
slay
Visitor
hi im using xperia pro....my whatsapp cant open eventhough I uninstall and install back for many times...i also reset my phone and I thought this will solve the problem but still the same..it keep telling " whatsapp unfortunatly stopped " please help me....
