The screen goes dark
SOLVED
matro
Visitor
Greetings to all
The screen of my sp becomes dark: it happens suddenly, doing different things and using different apps. Screen freezes and darkens to become dark yellow, almost the color of a scroll. This takes about 5 seconds, during which the screen does not work: after that, is released and returns to work.
I can fix it or do I contact support?
Thank u
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
matro
Visitor
Problem fixed: the solutions are replacing the display module and software reprogrammation, that's what the Sony technical assistance did. The made a great job in less than a week.
13 REPLIES 13
Thommo
Try performing a system repair using Pc Companion as this will often fix issues - This will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
Uliwooly
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
microbiom
Visitor
Hi! I have the same issue, and as I know, this is a kernel bug related to 4.3 .205 and . 207. It doesn't affect all xperia sps, and depends on the diplay panel type, because the graphic driver is not perfect for one of them. Sony didn't releas any software repair to solve the problem, and I think they won't do anything about it, because software support of this model is over.
matro
Visitor
I did as you suggested: I performed the reset.. I try to use it for a few days and I'll tell
Bye
matro
Visitor
I hope not, I love this phone
Uliwooly
Did PCC worked?
matro
Visitor
Yes, it did, i managed to bring it back to the factory settings by following the procedure: now i will take some days to see if t works
Uliwooly
Great to hear that, keep us updated
matro
Visitor
Hi, unfortunately it happened again, several times during the last week. Other suggestions? The phone is still under warranty. Thanks
