Problem after upgrade
Nicht anwendbar
I have just done an upgrade on my X10, prior to this i did a backup of everything using a free 'mybackup' from the android market.
I am now unable to restore everything as i can not find the app again.
I used a hotmail email to register for the 'mybackup' but i am unable to get phone to recognise this.
Please help as i ahve lost all numbers, messages etc
4 ANTWORTEN 4
uliwooly-wooly
Legende
for future reference
settings > privacy > make sure both are selected "back up my data, automatic restore"
Make sure you backup everything
Backup & Restore app
Use this links to download the apk
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Nicht anwendbar
Does this mean i have to install the app again?
When i go to the above link on my phone it says it is already installed, but is not anywhere on my phone.
I also think i maybe didn't save to sd but to a local area
uliwooly-wooly
Legende
it will say that it's installed because you already installed it, but that doesn't mean it's on your phone, so just re-install it
