My X10i vibrate when i use the keyboard?
SOLVED
Not applicable
Hi Guys n Girls,
My phone has suddenly started to vibrates whenever i use the keyboard not only in the messaging but anywhere! how do i turn this off? i can't seem to find the option to!
Cheers
Damian
1 ACCEPTED SOLUTION
Accepted Solutions
suze
Leader
Hello there, if you go into Menu>Settings>Locale & Text and then select the keyboard you are using there should be a tick box to turn the vibration on or off.
Hope it helps.
4 REPLIES 4
Not applicable
if you go into settings then locale and text then tap android keyboard make sure vibrate on keypress is not checked. hope this helps
suze
Leader
Hope it helps.
Not applicable
Thanks a lot guys!
Not applicable
your very welcome
