How to manually update, root, downgrade 2012 Xperias
SOLVED
How to manually update 2012 Xperias to Android 4.0.4
Click on one of the topics
as always thanx XDA forum
Rooting "might" void your warranty. I'm not responsible if anything happen to your phone (nothing should go wrong,, if something do go wrong, just repeat the whole process).
201 REPLIES 201
Madaditya
Visitor
Thats the point where i go wrong i guess! i actually don know weather its installed or no??as per instructions i extracted them in the folder inside android-sdk,,,
usually installs are setups..eg exe's apk's...so confused
sorry for noobiness!
Uliwooly
Madaditya
Visitor
i followed the instructions on this link...but to no effect! still says Anguished_Face
Uliwooly
I've read a user who had the same issue, let me see if I can find what he did to solve this
Madaditya
Visitor
Ill be thankfull to you!:smileyhappy:
Thommo
If you've installed Fastboot then on your C: drive there will be a folder called Fastboot inside this folder will be another folder called usb_driver now open your device manager and connect your phone in Fastboot mode and look for a driver issue normally denoted by a yellow mark - Right click this and choose update driver and choose the manual method and direct it to the folder mentioned above to update and install the correct driver - once done hopefully the yellow mark will go and you can then carry on to unlock your Bootloader
Failing that I can offer assistance via Remote networking using Teamviewer
Rey
Visitor
The Xperia U SI list is NO LONGER available ! And the thread is obviously closed.
So HOW can we know where and if there will be (one day, before the end of the world) an ICS update, for whom stil NOT have the update available ?
Must we consider Sony abandon the Xperia U and there are only luky customers who could have the ICS update ?
There is NO WAY we flash ourselves the phone, in which case we lost guarantee.
Uliwooly
as you can read on the warranty part of the thread it doesn't void the warranty, it "could"
Rey
Visitor
Ok, i've done it.
But ICS is bugy. WiFi has lot of issues. For me, after a long time of use, it is impossible to switch of the wifi. I must power off the phone Angry_Face
Is there still no new ICS or JB update list for the Xperia U ? Since they deleted the list, we can't know when our phones will be updated. As i already said, some people have had chance to be updated and some others no (in same country). This is NOT fair.
I want a real Android 4 update because the one i used lack lot of functionalities and is not very stable.
Lol, and there is no flash support when 2.3 is flash supported !
DesOLatE
Visitor
Honestly I don`t know why a lot of people faces so many problems with the new ICS, mine works perfectly but that`s not the the main reason of my post. I want to know if Sony will upgrade the OS from ICS to Jelly Bean and when this will be available.
