How to manually update, root, downgrade 2012 Xperias
SOLVED
How to manually update 2012 Xperias to Android 4.0.4
Click on one of the topics
as always thanx XDA forum
Rooting "might" void your warranty. I'm not responsible if anything happen to your phone (nothing should go wrong,, if something do go wrong, just repeat the whole process).
1 ACCEPTED SOLUTION
Accepted Solutions
201 REPLIES 201
Uliwooly
1st Backup everything
2nd Backup your current firmware
3rd Follow the steps bellow to flash your phone (remember I'm not responsible if anything happen to your phone and this "might" void your warranty)
4th enjoy
it's useful to have
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
Download FlashTool or Here
Download the FTF file
FTF files:
Xperia T TX V 4.3
Xperia S Jelly Bean
1
2
Xperia SL JB
6.2.B.0.211
.200
Xperia SL 6.1.A.2.45
1
2
Xperia S 6.1.A.2.45
1
2
3
.453
alternative
Xperia Ion (if you have AT&T exclude baseband)
Jelly Bean
ICS
1
2
3
Xperia Acro S
Xperia U
6.1.1.B.1.10
Xperia P
JB 6.2.A.0.400
1
2
3
6.1.B.0.550
 or here
Xperia Sola
6.1.1.B.1.10
Xperia Go
Jelly bean
6.2.A.0.400
1
2
3
6.1.1.B.1.1.0
 (French)
Global
Xperia T (if you have the AT&T variant exclude baseband)
9.1.A.1.141
Xperia T 9.1.A.1.140
JB 9.1.A.0.489
1
Dutch
ICS
7.0.A.3.197
1
2
7.0.A.1.303
or
Xperia Tipo
Xpria TX
JB 9.1.A.0.490
or
Here
ICS 7.0.A.3.212
Xperia V JellyBean
Xperia J    11.2.A.0.21
Neo L
Xperia E
11.1.A.0.64
Uliwooly
How to create a backup of your original firmware
you must have SUS
run SUS and repair your phone
go to C:\Program Files\Sony Ericcson\Update Service\db\13740270\blob_fs\
Copy the 2 largest files you'll find there to C:\Flashtool\anynameyoulabeled it as
Run FlashTool
Click Advanced > Decrypt Files
Source folder : C:\Flashtool\anynameyoulabeled it as
From Files, select all (Click & Ctrl + A) and click -> to move the 2 files to Files to convert
Click OK
Wait patiently till it finishes...
From Folder list, select all (Click & Ctrl + A) and click -> to move the 2 files to Firmware content
If it is ICS, tick the Disable Final Verification Check
13) On Device write the model [ex. Xperia Neo V (MT11i)], on Version write the firmware version and/or the Android version [ex. 4.1.A.0.562 (ICS_4.0.3)], on Branding write the region and your name if you wish.
Click OK
On Device Selection choose the device it is for (ex. MT11i)
Wait very patiently...
When it finishes the .ftf file is located on C:\Flashtool\firmwares
Thanx leajian
http://talk.sonymobile.com/thread/36355
Uliwooly
Uliwooly
Rooting & Warranty
Rooting
How to ROOT with LOCKED Bootloader
http://forum.xda-developers.com/showthread.php?t=2186368
Thanx Binary
http://forum.xda-developers.com/showthread.php?t=1886460
Xperia S Jelly Bean Root
http://forum.xda-developers.com/showthread.php?t=2327473
How to root Xperia P Jelly Bean
http://forum.xda-developers.com/showthread.php?t=2249077
How to ROOT with LOCKED Bootloader  (Special thanx to Sharaz22 at XDA Forum)
http://forum.xda-developers.com/showthread.php?t=1742992
Warranty
From sony mobile developers
http://unlockbootloader.sonymobile.com/instructions
Warning! If you perform this step, you will unlock the boot loader.This may void your warranty and/or any warranty from your operator. If you still want to unlock the boot loader of your phone, enter fastboot.exe -i 0x0fce oem unlock 0xKEY, where KEY is the unlock boot loader key you got in the beginning of this instruction. The boot loader should now be successfully unlocked.
from Sony mobile
Warranty Document
http://www-support-downloads.sonymobile.com/common/warranty_phones_US_12.pdf
Nor does this warranty cover any
failure of the Product due to accident, software or hardware
modification or adjustment, acts of God or damage resulting
from liquid
in other words it "could" void your warranty
Uliwooly
How to use flashtool
Install it and you will see  5 folders
                                   Custom
                                   Drivers
                                   Firmwares
                                   Loaders
                                   X10Flasher_lib
take the firmware to the  "Firmwares" folder
click on Falsh
Press Ok
it will ask you to connect your phone on Flashmode (turn off your phone, press the Volume Down, then connect the USB) press OK
This is an step by step guide
Uliwooly
How to Downgrade
Xperia™ S, 4.3 inch screen
S
Xperia™ P, 4 inch screen
Xperia™ U, 3.5 inch screen
Xperia™ sola, 3.7 inch screen
Sola
Xperia™ acro S, 4.3 inch screen
Acro S
Xperia™ go, 3.5 inch screen
Go
Xperia™ ion LTE, 4.6 inch screen
Ion
Uliwooly
Uliwooly
It's time Xperia S 4.0.4
3eb
Visitor
Here's the link to ICS Switzerland Generic Slightly_smiling_Face
http---www.ambroosvaes.be-Xperia-LT2...1257-3740_.rar
