hi there, when i turn on the megabass function and increase the volume above level 6, my sound gets distorts. i am using sony ericsson hpm70 headset and found no problems with the headset on other phones. please help me to overcome this issue.
Solved! Go to Solution.
ok, so do i have any means to update only the megabass function via phone? or should i await for the new version to be released?
No you don't.The phone's remote update service will either download a new update, if there is one, or it will just tell you that you already have the latest software.The SE Update service application however (via PC), will also give you the option to clear and re-install the same software even if you have the latest version, something which can clear up software glitches in some cases.Either way, this involves downloading the software for the entire phone but sadly, you can't choose to specifically update a particular function.Perhaps this should be the way forward for SE!
ok then do you guarantee that i will not face the shortcomings as others are facing in the forums? shall i proceed with it? because this is my new phone and other things perfectly works well except megabass
I can't guarantee you that, as I'm just a member of this forum like you are and don't work for SE.
Ok then how can i contact the SE team to get advice regarding this? pls help
ok i have placed a mail for them.. will check out what they say. anyway, thank you Dr. Chris!
Rizwan
May i know how you have overcome this problem because i am having the same problem with my phone Cedar .
can you please help on this ?
Thanks,
VIgnesh M
