Error when flashing with Flashtool!
Rayday
Hello there, I am trying to Flash my Phone back to 4.1.2 but it has Errors. Initially, it was the b2 boot up error or something now it is SEMC flash device ERROR!!! Please help?
26/002/2014 17:02:39 - INFO - Please connect your device into flashmode.
26/003/2014 17:03:12 - INFO - Device disconnected
26/003/2014 17:03:41 - INFO - Opening device for R/W
26/003/2014 17:03:41 - INFO - Start Flashing
26/003/2014 17:03:41 - INFO - Processing loader.sin
26/003/2014 17:03:41 - INFO - Checking header
26/003/2014 17:03:41 - ERROR - Processing of loader.sin finished with errors.
26/003/2014 17:03:41 - INFO - Ending flash session
26/003/2014 17:03:41 - ERROR - Error flashing. Aborted
26/003/2014 17:03:42 - ERROR - Drivers need to be installed for connected device.
26/003/2014 17:03:42 - ERROR - You can find them in the drivers folder of Flashtool.
26/003/2014 17:03:53 - INFO - Device disconnected
26/003/2014 17:03:58 - INFO - Device connected with USB debugging off
26/003/2014 17:03:58 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/005/2014 17:05:43 - INFO - Device disconnected
19 ANTWORTEN 19
Rayday
Okay, Thanks a bunch bro. I am installing all of them too, Haha
Dreammy
Can a TFT file be linked to a certain location ( read: country )
OR
Could it be if i use THAT TFT that it wont work in my country because of reason x,y,z
Where is this coming from: After flashing, my phone seems simlocked somehow. Everything else works perfectly. I didnt have any errors while flashing. When searching for TFT files I saw some with the name of the country in the name like this
blabla.australia.tft
JossoSan
Got the same issue (Processing of loader.sin finished with errors.) while flashing a Z3 to D6653 Customized Hong Kong.
Deepak2
error flashing. Aborted sony xperia C3
please help me.... i cant operate my xperia C3
waseem_tiptur
what is this Sp
im also Suffering From Same Problem
here is log
16/010/2015 19:10:36 - INFO - Flashing finished.
16/010/2015 19:10:36 - INFO - Please unplug and start your phone
16/010/2015 19:10:36 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
16/010/2015 19:10:36 - INFO - Device connected in flash mode
16/010/2015 19:10:37 - INFO - Device disconnected
16/010/2015 19:10:42 - INFO - Device connected in flash mode
16/010/2015 19:10:52 - INFO - Device disconnected
16/011/2015 19:11:54 - INFO - Selected Bundle for Sony Xperia C (C2305). FW release : 16.0.B.2.13. Customization : Generic World
16/011/2015 19:11:54 - INFO - Preparing files for flashing
16/013/2015 19:13:36 - INFO - Please connect your device into flashmode.
16/014/2015 19:14:39 - INFO - Device connected in flash mode
16/014/2015 19:14:39 - INFO - Opening device for R/W
16/014/2015 19:14:41 - INFO - Reading device information
16/014/2015 19:14:41 - INFO - Phone ready for flashmode operations.
16/014/2015 19:14:41 - INFO - Opening TA partition 2
16/014/2015 19:14:41 - INFO - Current device : C2305 - QO3C09C12925
romm
Processing of system.sin finished with errors.
03/022/2016 19:22:36 - INFO - Ending flash session
03/022/2016 19:22:36 - ERROR -
03/022/2016 19:22:36 - ERROR - Error flashing. Aborted
03/022/2016 19:22:36 - INFO - Flashing finished.
03/022/2016 19:22:36 - INFO - Please unplug and start your phone
03/022/2016 19:22:36 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
03/022/2016 19:22:36 - INFO - Device connected in flash mode
03/022/2016 19:22:37 - INFO - Device disconnected
03/022/2016 19:22:39 - INFO - Device connected in flash mode
aschenberg
Please help! Crying_Face Yesterday my Xperia Z3 Dual D6683 suddenly shutdown.When I press start button,it just boot loop in sony logo.I try use pc companion.it success repair buat nothing happen with my xperia.Then I use flashtool, but it stuck in processing loader.even I waiting until 2 hours nothing changes. someone help me! Capture.JPG
mick6751
I get this error doing it to a sony xperia xa
5/045/2018 14:45:36 - INFO - Opening TA partition 1
25/045/2018 14:45:36 - INFO - Start Dumping TA partition 1
25/045/2018 14:45:37 - INFO - Finished Dumping TA partition 1
25/045/2018 14:45:37 - INFO - Closing TA partition
25/045/2018 14:45:37 - ERROR -
25/045/2018 14:45:37 - ERROR - Error dumping TA. Aborted
25/045/2018 14:45:37 - INFO - Opening TA partition 2
25/045/2018 14:45:37 - INFO - Start Dumping TA partition 2
Nade_shazam
I installed ALL Drivers and rebooted my pc and it did not work.  It still keeps looping.  I un-installed the flash tool and re-installed and I re-downloaded the FTF file and it did NOT solve the problem.
bibibabi
I can say the most stupid reason in the world for which a cancellation of the operations appears after this line of log:
"Opening device for R / W"
  using flashtool.
REASON: I had the EMMA flashtool open that the phone could hear.
SOLUTION: close EMMA, and maybe restart a flashtool64 moment.
I read the whole discussion, then suddenly the existential doubt!
Emma was interfering!
