Date and time of a picture
SOLVED
Not applicable
Is it possible, without installing additional applications, to see the exact date and time when a picture in the photo album was taken?
1 ACCEPTED SOLUTION
Accepted Solutions
suze
Leader
If you view with Explorer using your PC and USB cable the date and time stamp are in properties.  Alternatively get a file manager on your Phone, Astro is a good one and shows date and time.
8 REPLIES 8
Uliwooly
just select the picture, press menu and tap on the (i) information icon and you'll get the info
Not applicable
When I select a picture in the album, I have only three icons in the corners: send picture (various options) at the top left corner, delete picture at the top right, and use picture at the bottom left corner - there is no info option. Also, when I press the left key, all icons just disappear, leaving the picture clear (for a better view, I suppose). The phone is at Android 2.1. with the newest update.
suze
Leader
You can't without installing a third party app as far as I can see.
Uliwooly
how about timescape?
Not applicable
I cannot see photos in timescape... I was hoping that Album could show the info.
Not applicable
It seems to me that this is very basic feature and that the built-in application should have it. Slightly_frowning_Face
suze
Leader
Not applicable
Thanks. I know that. Also, I can also use Skype on my PC instead of a phone. Winking_Face
