I recently bought this phone (last firmware). I found the following errors in the sms management saved in the sim:
One point more: If I connect the phone (Elm) to the PC (with Sony Ericsson PC Suite) I can see all the sms's on the SIM.
I contacted with Sony Ericsson support, they told me that run an upgrade. I dit it, same result. Then they said me that expose this bug here, in talk.sonyericsson.com.
Any solution?
Sorry for my English.
Solved! Go to Solution.
Try phone repair with PC suite and failing that, a master reset.
Thanks Dr_Chris, now I can see and save up to 20 sms on the SIM. But I still don't understand why the SIM tab doesn't appear in "Messages" > "Manage messages" ?, and it only appears when the sim is full and you try to save one more sms, then the phone ask if you want to delete some sms. When you accept, then there is SIM tab.
Main menu--Messaging--Messages--Saved messages: These are your SIM messages and from here you can view and delete them.When you opt to save a message, it means to save it to the SIM card.The Manage messages option is to move messages between the phone memory and memory card, but not the SIM card.
