Xperia L keep Restarting
SOLVED
tonyjaimy
Visitor
When i start with sim it restarting again and again
Because of this i can't make calls
Please somebody give me a solution
Please help me
1 ACCEPTED SOLUTION
Accepted Solutions
tonyjaimy
Visitor
@jenny what abw GPS is it On or off?
If off please turn it on
Maybe your problem will solved
14 REPLIES 14
Uliwooly
@tonyjaimy
You have either a faulty SIM card or you trimmed/cut a regular SIM card, which doesn't fit properly causing this. Solution: get a brand new SIM card.
tonyjaimy
Visitor
It's not because of sim card
I tried more than 2 sim cards
Uliwooly
@tonyjaimy
Do you expect any restarting issues w/o the SIM card?
tonyjaimy
Visitor
Without sim card....
No problem
Uliwooly
@tonyjaimy
There you go, the problem is indeed the SIM card, get a brand new SIM card and report back.
You can also boot on >>>  safe mode and try again
tonyjaimy
Visitor
Any other solutions?
Uliwooly
@tonyjaimy
You could repair the phone with PCC, but most likely you need a brand new sim card
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
jenny7
Visitor
If sim card is problem then that simcard work properly in other mobile & I have tried without sim card then also it is keep restarting. & I have also tried other sim card, still the same situation.
The problem was started when the msg came that whatsapp has stopped. After that all the apps like Google play store, gmail, yahoo etc. has stopped. This msg was coming on screen automatically & after that the msg came 2-3 times that android has stopped & then this restarting occur.
I just need a solution, I have taken this phone recently just 1 year back.. & this kind of problem occur. Pathetic standard of sony. Please I need a solution. Kindly help me out.
tonyjaimy
Visitor
