charging problem
RENIT
charging problem
I NEED HELP AS SOON AS POSSIBLE  !!!!!!
I KEPT  MY PHONE FOR  CHARGING AND AFTER FEW HOURS  THE  BATTERY % STILL REAMAINS D SAME AND I HAVE NEVER SEEN MY BATTERY ABOVE 15 % !!
25 ANTWORTEN 25
profile.country.RO.title
_alexdon_
I am giving you solutions,hopefully if you repair via sony update service it should be fine:
http://www.sonymobile.com/gb/tools/update-service/
alexdon
RENIT
is it because of some hardware problem ?
RENIT
its already in the latest update  Neutral_Face
_alexdon_
After SUS checks your version,it should let you repair.
alexdon
RENIT
mine was updated to the latest
Danial-mach1
Alter Hase
no...you should not update..you must repair...even you updated to last firmware you have repair option
RENIT
ok
RENIT
there is no repair option
Danial-mach1
Alter Hase
RENIT
there is no factory reset
