Got a little problem with a new HDD recorder and I've tried everything
to sort it but can't get anywhere.
Setting programs to be recorded is easy,just go to the guide select the program single or series and thats it.
The problem occurs when a program is repeated on the same day. The recorder opts for the early version of the program and not the later one selected.
Trying to set manually will only set a single program.
Any suggestions would be welcome.
