Change clock frequency for Sony FCB-EV7520A
AKSadk
currently i am working with camera Sony FCB-EV7520A. The communication with the module is achieved via LVDS interface using VISCA protocol. As you can see in the attached photo, it is written that for the output format 1080p/30 the Pixel CLK should be 74.25 MHz. But the problem is: when i set the frame rate to 30 frame per second using the hex command  (81 01 04 24 72 00 07 FF), the clock output remains at 148.5 MHz.
How shall i change the clock frequency of the module?
Looking to hear from you.
regards,
6 ANTWORTEN 6
Julia-W
Moderator
Hi AkSadk,
this is the German Community you posted your question to.
You might want to consider asking in the English-Speaking community if you don't get answers you were looking for here.
Best regards,
Julia
(Community Manager)
AKSadk
Hallo Julia-W,
i could not sign in to the english speaker as i created my account as a german user. I am getting sign in error when trying to sign in to the english forum.
Kind Regards,
AkSadk
Julia-W
Moderator
Hi AKSadk,
you might need a separate account for the English Community.
Best,
Julia
(Community Manager)
IamNic
Hello @AKSadk,
simply exchange the ".co.uk" with ".de" and your account will work there.
This link has already been modified, so it will work just by clicking it and then clicking "Sign In": https://community.sony.de/t5/english-community/ct-p/en
AKSadk
Hallo @IamNic ,
thanks a lot for your answer.
Regards,
IamNic
Hello @AKSadk,
you are very welcome.
