DSC-HX90V usb not detected
SOLVED
keithyt1958
Explorer
sony dsc-hx90v when i plug in usb its not detected although camera shows plugged in instead of battery
in device manager i have uninstalled all usb devices and reinstalled although sony cam is not showing
set usb to mass storage and usb power is on tried usb power off and tried mass storage to auto i have also tried usb on laptop but not detected on that either.
nothing in file explorer and i have ordered another usb cable also done a reset (initalise) but did not help.
1 ACCEPTED SOLUTION
Accepted Solutions
keithyt1958
Explorer
Bought a new usb lead from sony uk fitted it and now usb on camera is working
can access media now.
6 REPLIES 6
profile.country.NL.title
Strampke
Did you start by installing PlayMemoriesHome on your computer?
Or did you just plug-in.
You already followed steps like on this web page.
On my computer there is one USB port that isn't always able to detect connected devices.
Happily the other port does.
keithyt1958
Explorer
yes i installed playmemories tried front usb and rear usb several ports also tried another computer (laptop)
but still not detecting usb and nothing in device manager.
IamNic
Hello @keithyt1958,
was the camera switched on or off when you plugged it into your PC? To transfer data, it has to be switched on, otherwise it will just charge.
keithyt1958
Explorer
tried connecting to pc with camera on also tried connecting to pc with camera off
when connecting to pc with camera on instead of battery it shows charge icon(plug).
keithyt1958
Explorer
Anonymous
Not applicable
Hi Keith,
Could you share the link from which you bought the cable, maybe this can help other customers.
