- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sound out of sync/distorted XH90
Anyone have any HDMI sync problems? Have a 65” XH90 connected to a BT UHD box. All was fine.
However the last week sound (only use TV speakers) now crackles/distorts, and goes out of sync.
Switching inputs, switching TV off/on, gets it back in sync. This happens for recorded programs and live TV via the BT box.
However using the TV apps, Prime, Netflix etc everything is ok.
So tried a new HDMI lead, and different HDMI port and the same result.
So I presumed it was the BT box, however just received a new BT box and it’s the same....
So is the TV broke? Why are apps ok, only the HDMI sockets broke?
Anyone anymore help please
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Really really disappointed by Sony though, that their engineers couldn’t identify this with resources they have.
Not sure how an app can cause all these problems thought either.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My fingers are crossed, TuneIn uninstalled and TV seems to be back to normal for the last few hours...who would have thought that an app would cause such mayhem with Sony TV's.. thank you for the fix and for posting it up, shame Sony didn't try it out and suggest it to their customers once it was posted up here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, so far all still seems ok with it. We did have two mornings after where when we turned the TV on, it turned itself off and back on again so not sure what that was. We only have this particular model 5 days so will continue to keep a good eye to it and if there's any more issues/glitches it's going back before the 28 days are up.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
I have this exact issue on my KD55A8. Started 7 days ago. I thought it was Sky but its the tv. Swapping HDMi ports and cables solved the issue for a day and then back to out of sync and crackling distorted sound. Phoned Sony who advised they are working on a fix .
fingers crossed 🤞
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Someone on here discovered that TuneIn radio is likely to be causing the issue.
So if you have TuneIn radio installed, uninstall it then switch the set off at the mains, leave for a couple of mins and switch on.
Worth a try. Might be quicker than Sony engineers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same issue with my XH90, I have just spoken to Sony and they have confirmed it is a software issue (although I disagree and wanted them to replace the unit which they wouldnt do until they had applied the fix). The odd thing is that I can factory reset the tv (again) and it works ok for around 3 hours, but then its turning it off and on again. I guess all we can is wait for the update before we can use our very expensive tv's. I thought it was something connected I even put the tv on wifi and that appeared to work and then the crackling.and distortion appeared again. So bloody annoying.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have you tried uninstalling the TuneIN app and then powering your TV off at the mains for a couple of minutes?
It has worked for many people (including myself)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you have tunein radio app on your TV, uninstall it and power off TV, it has worked for a lot of us
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have you tried the uninstall of the TuneIn radio app, it seems to have worked for others on here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you have uninstalled the Tune in App and lets see will know it about ten minutes. Might just restart anyone but its ok now.
