- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony Bravia google play not loading movies
Hello
my sony bravia will not play movie’s on google play. The app opens and i can pay and sometimes watch trailers but when i try to watch the movie it tries to load then comes back to the google play app.
Clearing cache etc does not work.
the only solution i have found is to disable and uninstall the app. Which then automatically re loads the app at its base un updated state. The movie’s then work perfectly. But after a little bit as it updates Itself the issue will re happen.
so everyday to watch a movie i need to uninstall the app.
is there a solution to this?
the tv has been recently updated but this issue has been happening long before this. Netflix etc all works perfectly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
Can you let me know the model number of your TV?
Best wishes,
Sean
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have been having the same problem for a couple of months on a Bravia 65X9300D. What I have noticed is that the problem only happens for movies with surround sound. Movies with stereo sound play fine, as do trailers. The update from Android 7 to Android 8 made no difference.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I don't have this issue on my XF
Do the same movies work in YouTube? (they should be in *my library")
Edit also suggest a soft reset by long press on the power button
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Re: YouTube question - yes they play from YouTube but that is only in stereo.
Amazingly, it has just started working again after not working for 4 or 5 months! The version of the Google Play Movies app is the same so not sure what has changed to suddenly fix the problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
KD-75X9400D
seems ok this week but will test it some more. Wonder if they did a new update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have just noticed the same thing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I use this feature almost every day and this week its now started to give me the same error when trying to use google play to watch movies. I have a Sony Bravia KD-55XF9005. Every time I try to play a film I get an error message. "There was an error." With a retry button. When you press the retry button nothing happens. As mentioned above if I uninstall the 'google play movie and tv' app and use the one supplied with the TV then I can watch the films. Looks like the latest app update has a bug on it stopping the app working on my TV. Every night the TV updates the app so every day I have to uninstall it after getting the same error. I have app version 4.25.5.10-tv installed which is the one giving me the error.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes have this problem myself as well now. "Uninstalling" removes updates so it works until the update is re applied
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have had the same problem recently, the solution for me was to uninstall the update 10/02/21 for play movies, and open the app again after unchecking the auto-update all apps box. I retried and it seems to certainly be the update dated 10/02/21 that is causing the problem.
