Sonos Beam ARC Problem
Mercedes2019
Explorer
Recently changed my Sonos system Beam, Bass, 2 Sonos 1,  around took the Playbar out and added a Beam that worked perfectly with an LG in another room.
Since I have connected it up, I have to reset the TV and unplug for it to recognise the Beam. This is a pain. I know their are issues but does anyone in simple terms have a work round? Thank you and keep well.
13 REPLIES 13
The_Black_Rose
Specialist
Hi Raichuu ,
Have you tried factory resetting the TV and the amp?
Cheers,
The_Black_Rose
Mercedes2019
Explorer
Thank you, I have tried everything. I have now replaced the Beam with a Playbar that uses the optical connection. That's sorted it all our
Mercedes2019
Explorer
Thank you, I have replaced it with a playbar connected through the optical
The_Black_Rose
Specialist
Hi Mercedes2019,
Happy to know that it works via optical ! If you connect the playbar via HDMI does the same thing happen?
Cheers,
The_Black_Rose
