First post - hoping I'm putting it in the right place!
So, my PS5 worked great on my old Sony OLED. I've just swapped to a Bravia 7 and while all the other inputs look fine, the PS5 colours are really washed out and faded.
After a bit of Googling, I know this can be a common issue but I can't figure out how to fix it! So far I've tried:
• Unplugging everything and plugging in again.
• Trying a different HDMI cable.
On the PS5:
• Trying HDR On, and On When Supported
• Trying Deep Colour Output off, and trying it on Automatic. (Currently on Automatic.)
• Trying the various RGB Range settings. (Currently on Automatic.)
No luck. If I swap from Game mode to something else, the colours improve but it gets unplayably laggy.
Any advice would be really appreciated!
Check your firmware version if its v112.626.100.1 dated 11.09.24 your pretty much screwed until sony decide to issue the fix for that broken firmware in europe. America has already recieved it over a month ago plus another update which drastically improves the tv's performance.
you can check:
https://www.avsforum.com/threads/sony-bravia-9-mini-led-discussion-thread.3299218/
and
https://www.avsforum.com/threads/sony-bravia-7-mini-led-owners-thread.3299221/
which documents all that is broken including game mode washing out. Not just for Ps5 but pc gaming too.
I along with others have already raised tickets concerning this firmware.
The standard response from sony, is stick your head in the sand and wait until we can be bothered to fix it.
Ah, you star. Was hoping for a quick fix, but at least I know I can stop fiddling with all the settings now!
I'll see if I can raise a ticket to complain too - seems daft that all my non-Sony inputs work great on the TV, and it's the PlayStation that isn't happy!
Unfortunately for my case its not just pc game mode washing out.
On any source gamma, black adj, adv contrast enhancer, live colour have no function.
Im also coming to the conclusion that reality creation, random noise, digital noise and motion are not functioning correctly either.
@Wheato new firmware appeared on my tv, not web as yet.
v112.627.030.1
Benefits and Improvements
Improves the overall performance of the TV
Adds support for features for Game play
Support for Gaming Multi View on YouTube
Support for the YouTube Quick Search on the Game Menu
Disables the Voice Zoom function when using simultaneous output
Fixes an issue where grayscale may be poor in dark scenes with Dolby Vision
Fixes an issue where Google Assistant handsfree may not work after the TV is in Standby
Fixes an issue where the Auto Adjust According to Ambient Light setting may turn on when starting Netflix
Fixes an issue where there may not be any sound after turning the TV off and on with the remote control
did a factory reset after the update.
Pc Game mode seems to be holding after 2hrs gaming.
all other issues i was having seem to be resolved as well.
Thanks! Just downloaded and installed. I *think* it looks better, but probably not as good as it did on our old TV.
Do you need to do the factory reset after installation or should it just be working?
it was a personal preference really. new firmware start clean.
but to answer your question, everything should just work.
