Is there anyway to reassign a diffrent app the the netflix button on the remote control?
I dont use netflix and have no plans to!
I would prefer this button load up PLEX or KODI instead.
Is this possible?
Gelöst! Gehe zu Lösung.
It's a bundled app - you cannot remove it. If this was a phone then you could root the device and then remove it but I don;t know of anyone rooting the TV yet
This not work for my tv. App just send me to unninstal netflix , but can't uninstal just disable Netflix. When disable Netflix nothing is going on. Button not work at all.
something not work
hi,
tnx for tips but unfortunatlyu doesn't work. I try reinstall app before and now and clean cash before uninstal, but nothing.
If I not stop or blocking netflix before start app, the app say: please go to next screen and deactivate netflix and then come back, and when I press OK app is crash... and say something :" unfortunatly app is crash please close it...or something like that"
If close netflix and disabe ti before start app, app is doing its work and let me chose which program to choose instead netflix but then is nothing going on. When I press netflix button is nothing, no netflix no some other app ( I try several apps)
I no idea any more...
I was,
He asked me a tv model and android version, I tell him, so now wait for answer.
kind regards
Hi @Budhi108
Have you tried a full factory reset of your TV?
https://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/66442/
Cheers
Hi, I not try factory reset yet.
for now I do not mind so much for Netflix button that make factory reset for that. Someone on the topic wrote that he had problems with the picture quality due to factory reset, so I'm afraid to experiment.
I made soft reset but nothing is change.
thx for advice
HI there
If you write down all your picture settings before a factory reset, then you can simply re-do them afterwards. Ive started creating a spreadsheet with the picture/sound settings etc (which is a work in progress), which can be found HERE - it could save you time
Cheers
