BBC iPlayer missing since Android TV v8 update
psellwood
I recently upgraded my Sony KD-49XD8305 to Android TV v8 and, whilst everything else continues to work, BBC iPlayer has disappeared and is no longer visible in the App Store.
I can’t find anything else online mentioning this issue and can only think that iPlayer hasn’t been updated to work with the latest OS yet.
Is anyone else having this problem? Does anyone have a fix or workaround?
46 ANTWORTEN 46
Tenneen9000
Hi psellwood,
That's weird. You can't find it when you press on the "Apps" icon in the Home menu? Also, the app never was available on the Play store as it's preinstalled.
Regards,
Tenneen9000
Pretency
I have this issue too. Youview also gone!
Tags (1)
MrJoBangles
It's maddening! All the terrestrial players have disappeared.... What are they playing at???? I can go into TVGuide (is this Freeview Plus, I dunno?) and find a recent show to play on catch-up but this is a clunky way of opening say , iPlayer, to find an older show that's not in the guide.
For Pete's sake put all the hubs/players in the app store so we can bung them back on the home screen.
LightFoot
Spezialist
gregmantis
Did you ever manage to resolve this? I've just had the V8 update roll out tonight and iPlayer has disappeared for me too. This is the only reference to the problem I could find anywhere online.
LightFoot
Spezialist
Hi @gregmantis
It is on Sony Select. Make sure that it is showing by going to Home -> Customise channels -> Sony Select _> Enable.
gregmantis
Thank you!
Unfortunately I'd already just performed a factory reset to try and see if that would help and I'm running into the Sony Select "An error has occurred. Please try again later." message that seems to happen after a factory reset as described here: https://community.sony.co.uk/t5/android-tv/quot-sony-select-an-error-has-occurred/td-p/2471759
The thread gives me hope that just leaving it for a few days might work in letting me access it.
Thanks for the reply!
SadieB91
I'm having the same problems, all terrestrial apps have gone and can only be accessed through the Freeview guide.
MrJoBangles
They have reappeared as the bottom rung on my HOME screen. They are not immediately visible as they are the 5th row and only top 3 rungs fit on screen. They are there when I scroll down
So, on my TV the rows on HOME screen are as follows;
Apps
Netflix
Play Movies & TV
Play Music
Sony Select
All the players are on this row. I can't remember if or how I customised and ordered these rows, I suspect I did at some point mainly to remove stuff I don't use.
So, make sure Sony Select is enabled to show as one of the rows on your HOME screen and you should then see domestic UK players on that row.
