Android 11 NFC not working
profile.country.RO.title
AlexManea.
Explorer
After update, when i try to enable NFC connection from the shortcut panel, it doesn't work!! Even when i enable the NFC connection from Settings Menu, the pictogram isn't on like Bluetooth for example.
Please fix it!
8 REPLIES 8
RottenFoxBreath
Enthusiast
Yeh, NFC is now only selectable from the Settings - Connections page where wifi and bluetooth are.
Been that way since 10, well on my Xperia at least it was removed last version for the settings selection.
profile.country.NL.title
Strampke
Just like the Portable Hotspot tile.
It's a Google policy that is has disappeared from the quick settings menu.
Remarkable that both NFC and Portable Hotspot disappeared and that Portable Hotspot was re-introduced in Android 11.
Time for a tip:
- on the home screen long press.
- in the menu tap Widgets
- scroll down to settings
- you will find a menu named Settings shortcut
- choose what you like to have as a shortcut on your homescreen
- NFC is not included in this list 😞
The good news is that NFC is nearer than it seems at first sight.
- long press the Bluetooth tile
- tap the Connection preferences
- there you will find the NFC toggle
You may have noticed that the long press on the Bluetooth tile shows a lot of Bluetooth information.
The same applies to the WiFi tile.
Long press it and you will find all WiFi spots around you. (when you have a little patience)
In fact every tile is a shortcut to the settings in the Settings menu.
profile.country.CL.title
acrolyu
Explorer
My xperia 10II does not send photos or anything by NFC other than the tag is not valid, I have android 10 !! The same thing happens to someone, how is it solved?
AlexManea.
Explorer
Hello,
I appreciate your response, but in 2021 i want a simple touch for opening an app or a service.
Not to keep touching the NFC, enter in the settings menu etc.
In Samsung phones, Google didn't this policy.
However, I hope they will fix this.
Have a great day!
RottenFoxBreath
Enthusiast
Try the Nearby Share tab..
EMS_MO72
Community Team
Hi there, try to do the NFC test from the support app on the device and check if it will pass or not.
If the test passed, try to enable your device on safe mode and check if it will work or not ?
AlexandruRai
Contributor
Do you have the latest 59.1.A.2.28 upgrade? What Customization you have?
AlexandruRai
Contributor
Great device, crap software and shameless responses from so called 'users' and 'care' when in fact they only have the jpeg of the phone, not in million years the device and understanding it and helping true fans. Fake fans and outsiders with hearts filled with sublime mercy!
Shame Sony!
Ps: Please check your device customization and give here a confirmation answer!
