Apps From Unknown Sources - Problem
SOLVED
Andy147
Visitor
Hi
Although my primary user account has "Allow Unknown sources" selected and I have no trouble installing apps there, I am unable to install the same apps from my secondary account.  It says I need to change the setting but it's greyed out in the secondary account's settings and not switchable.
How do I fix this issue?
Thank you.
1 ACCEPTED SOLUTION
Accepted Solutions
Rickard
Master
With Android 5.0, there's an issue with enabling unknown sources in other user profiles but this was changed in Android 5.1. There's a discussion about it here with a response from Google: https://code.google.com/p/android/issues/detail?id=79728#c179
As the latest version available for Z4 Tablet at moment is Android 5.0 i'm afraid i don't have any solution for you. You could perhaps try to install the app using ADB as described in the thread at Google and see if that works.
17 REPLIES 17
Uliwooly
@Andy147
That seems to be a lollipop restriction
Uliwooly
@Andy147
What kind of account is the secondary account? just tested this with a Z3 and you can select from unknown sources
Andy147
Visitor
Hi uliwooly, thanks for your quick response.
It's a second standard user account, not a guest account.  What's strange is that a message box appears telling me I need to change the setting, there is even a button in the message box that takes me to the correct setting page, but as I said, the "allow Unknown Sources" button there is greyed out.
Uliwooly
@Andy147
Create a new account and check again.
Andy147
Visitor
OK, did that, just the same unfortunately.
Uliwooly
@Andy147
I'm sorry to hear that, perhaps @Johan could comment on this.
Jake-SonyXperia
Champion
Hi Guys,
I have just tested this on my own device, mine is greyed out also, this sounds like some variants will allow it and some will not.
profile.country.RO.title
_alexdon_
@Jake-SonyXperiaSupport@Andy147@uliwooly
I remember Rickard said a guest account or other than owner account cannot install apps.
@Rickard Could you shed some light?
alexdon
Andy147
Visitor
OK, so is there anything I can do to fix it?
