Has anyone found a solution to the problem above?
Any advice?
Thnx
Hi dremicky and welcome.
Can we have more details please: -
When do you get this error?
What are you doing when it happens?
Are you trying to connect something by USB? If so have you installed the driver for the USB device before trying to connect?
Are you connecting a Plug and Play device? If so is the 'Plug and Play' Service set to run automatically at startup and is it running now?
The more details you can give the better.
