Losing Internet connection
Dear All,
This problem may have already had an answer posted somewhere, i have checked but cannot find the answer.
I have a one week old Sony Vaio VGN-FW31J running vista premium. The problem i have is staying connected to the internet, signal strength is excellent and another laptop i have stays connected fine.
I can connect and use the Internet,somtimes, but after a few
minutes my connection status changes to "local only". Sometimes it
will reconnect again on its own and give me internet access.
Sometimes I have to change the 'profile' in the LAN settings on the VAIO smart network. Eventually is seems to stay connected but if i close explorer and reopen the problem will reappear. I have hunted the internet and a number of people seem to have a similar issue with their VAIO but cannot find a straight forward answer.
How can I make the connection more stable?
Thanks for hopefully being able to point me in the right direction
Martin
2 REPLIES 2
Blencogo
Hi Martin and welcome to Club Vaio.
You can try three things: -
1. The most successful fix is to download and install the latest Intel WiFi driver - you can download it here: -
Intel 4965AGN Ver 12.2.0.0
Start Button -> Control Panel -> Network and Sharing Centre -> Manage Wireless Networks
Right-Click on your Network and choose Properties
2. Turn off the TCP/IP IPv6 option
3. On the Connection Tab, UNCHECK 'Connect to a more preferred network if available'. Make sure the other two boxes are checked.
Not guaranteed fixes - but well worth a try!
:wink:
Thanks,
have been scouring the internet looking for a 'cure' i updated the driver (never had to do that before, always slightly concerning in case you make everything worse), so far its worked a treat, connecting straight away and not lost connection once.
Thanks again
