My 2 months od Z3 Compact reboots when receiving inncoming calls. This mostly happens if any other apps are open or in use, not when phone is just in 'idle'. Have tried to switch between WCDMA, GSM only, WCDMA (peferred) GSM and LTE (preferred)WCDMA/GSM - no change.
Have run 'repair phone' through support' new install(?) - no change.
Have tried to reset to factory - no change.
Whenever this happens the incoming call is not registered as 'missed call' in the call log.
Tempted to throw it away!!!
Solved! Go to Solution.
The phone has been working without any problem since I got it back. Another thing I have noticed: the phone runs quite a bit 'cooler'. Before I sent it in, could hardly touch the back after 10-15 minutes of active use on the net or 'candy crushing'. Excactly what caused what to break I do not know. Was it overheating that made the motherboard fail or the motherboard causing the heat?
New SIM when I got the phone. This problem started after latest Lollipop up-grade as far as I have noticed. The caller ID and number comes up when the phone is ringing, which gives it gets registerd by the phone at the moment, but not logged. Phone does not reboot if I just let it keep ringing, only when I answer. To me it may look like a power drop that happens when answering making the phone reboot?
That's quite odd, you might want to get your phone checked at your local Xperia Care
http://support.sonymobile.com/global-en/contactUs/
does it happen while on safe mode?
Thank you, got me a 'ticket' number - waiting for a reply. Will try to post the solution when/if solved.
Hi Haffiman,
Just to let you know - you are not the only one with this problem.
I've searched the web, and I'm glad that I found you with exactly the same problem.
Please keep me updated, if you find a solution, and I will do the same to you..
Got a quick reply from support:
Dear Morten, ............................................................... |
My reply:
To insert the nano SIM card
If you insert the nano SIM card while the device is powered on, the device restarts automatically. |
Perhaps getting a brand new SIM card might solve the issue, if it doesn't then you need to take it to your local Xperia Care as it could be a hardware issue.
The design for installing the SIM card gives quite a loose fit and it may all come down to tollerances and thickness of the SIM card itself. I'll follow up and see what happens.
