Upgraded software to 5.1.1 and since then the ring volume turns itself fully down and won't let me adjust. All other volumes are working fine.
Will work for a little while after turning off and on again.
Any ideas?
Solved! Go to Solution.
I'm glad to hear that it works now
I have the exact same problem, and have only had my phone for a few days (purchased 2016-09-13). Volume will work for a certain amount of time, then will go on silent. DND not activated, at all. I work on call and first responder for a busy maternity unit and I must be able to answer my phone! I will return it ASAP if there is no permanent solution that I can access (living remotely).
Hi!
I have the exact opposite problem. I can't turn the alarm volume down. I've set the alarm volume below medium volume on settings but every time the alarm goes on, it is on maximum volume. That is really loud. Not anything one would like to wake up to at 5am..
Please help!
I'm almost having a heart attack every morning and the person sleeping next to me is pissed.
