Dears,
I have updated my Xperia Z to 4.2.2 yesterday. It is different, a lill bit.
Did not find major difference, except for the lock screen widgets.
This feature worked fine yesterday, after I did the upgrade.
Surprisingly, from this the widgets from lock screen have disappeared.
I don't see the camera widget on right and add widget option to the left.
Has someone faced similar issue?
How do I fix this?
Thank you,
Regards,
Amit
Gelöst! Gehe zu Lösung.
simple, you have another app that its blocking all this, I see a lock icon on the top right of your screen
also stay away from
taskillers, antivirus, ram apps battery apps, booster apps, task managers
Haven't heard this before. Have you tried to restart your phone by press and hold the power button and the volume up button at the same time until the phone vibrates?
If the problem persists, can you take a screenshot and post it here?
Hi Alexander,
Thank you for the repsonse.
I tried restarting the phone, infact I have tried it before as well.
Doesn't help
Below I've attached a screenshot of my lock screen.
