Sony Xperia Z HDMI Cable/Adapter [HELP]
ScottUzoho
I have a Sony Xperia Z and I used to have a Sony Xperia S. I used to use the HDMI cable to connect it to my TV all the time to watch films and send emails etc. however with the Sony Xperia Z I cant seem to find any working HDMI cables - I can only see adapters. I'm not sure what to buy to plug into the adapter or even if the adapter will work and the one for the Sony Xperia S doesn't seem to fit. Thanks.
If you know or have one I would really appreciate links to the adapter or/and cables i need to buy to get the HDMI cable working.
If you need to get an adapter I would really appreciate if you could send me a link the the cable that will fit into that specific adapter due to me buying 2 and them not fitting.
Arjun
Hi there xperia z needs a mhl adapter in order for hdmi to work
The mhl cable for samsung galaxy s2 works perfectly with xperia z you can buy from http://www.amazon.com/Samsung-MHL-HDMI-Adapter-Packaging/dp/B005LGUDKK or you can search for it on the internet
5 ANTWORTEN 5
Arjun
Arjun
Here is a video explaining how to use mhl adapter http://www.youtube.com/watch?v=RHa56Dm2j_8
ScottUzoho
Thanks guys. Really appreciate the links. I think I'll get the galaxy one then. Do you know what type of hdmi cable fits into the adapter (is it just the default hdmi cable)
Thanks again.
Arjun
Yup a normal hdmi cable would work with it
ScottUzoho
Thanks! Perfect and really appreciate your help man.
