Hi, 2 years ago I have buyed a Sony Xperia z3, now the smartphone I don't know why continue to turn on and turn of
Solved! Go to Solution.
you are experiencing what is called a Bootloop.
1.) try to remove your sd card and sim and boot your device.
or
2.) charge your device for 1-2 hours using the wallmount charger
3.) connect your device to a pc and perform software repair using Xperia Companion
or
Thanks for your help. seems to be working fine now
