Hi! Please help me. I deleted all APN in my phone, now i dont have the internet, except wifi is working. What can I do? Thank you
Solved! Go to Solution.
Open Settings then More near the top then open Internet settings and tap accept then from the list choose your network but make sure to select the right one as sometimes there are two 1.Contract and 2.PAYG then it should update and you're all sorted
hi! thank you for your help.
i opened settings and then More, but internet settings i cant find, i dont have the mobile phone in english. Can you please tell me which is in order?
Bottom option
I found. Tank you thank you very much
Don't forget to mark the correct answer and give kudos if you think I've helped
