Headphone volume too low
Flynny1878
Visitor
I have recently purchased the Z3, particularly for its advertised audio features.
Unfortunately, the audio volume does not go loud enough in all 3 sets of headphones I have tried.
Is this normal?
18 REPLIES 18
EllePi
Visitor
What volume do you get, using the loudspeakers?   Neutral_Face
barabbas
Visitor
I just got my new Sony xperia Z3 and I am realy upset because the volume when using headphones is set so low that I can just say hear it had I known of this problem before hand I would have stuck with Apple Iphone one verry unhappy Z3 owner I think if Sony does not resolve this problem soon then the phone will die a death
eida33
Visitor
I'm sorry to hear you're having issues with your sound quality. Please note that when you use a headphone, make sure you open walkman and increase the volume from there. You will not get this notification if you increase the volume without having the walkman app open. A pop up will say that "going above the volume limit is not safe etc." Make sure that you accept the risk and the volume should increase. Also check the settings in walkman, enable ClearAudio. Finally, make sure the volume on your headphone (if applicable) is the highest.
Good luck.
scarrabri
Visitor
Good luck.
The volume is much too low and for a phone this expensive i would expect better ,and there is no notification
allowing one to increase the volume when up full like there used to be ,and quite honestly the  decision should be mine on how low or high  the volume should be ,and there is still time to send this phone back ,which might act as a wake up call for Sony ,best wishes Brian.
SergioPL1
Contributor
If volume at 100% is low for you I would immediately consult a doctor. Volume output using normal headphones is quite high and as said above with security Check at quite low level.
Zaiaku
Visitor
I've been having the same issues with headphone volume aswell.  Its nowhere near what it should be for this phone.  All of the clear auido and other settings for this phone that is suspose to make it better, dont.  It just lowers the volume further.  I made a comparision with my old phone, a Motorola Atrix HD, using the same song bluetoothed from one phone to the other so it would be the same file.  The motorola has a higher max then the Z3 has.  And its the same with both sets of headphones I own.  Im a metalhead so sound AND volume are important...So far the Z3 only has the first.  Is there a way to make this louder?  and no, its not that I cant hear it, I just want it loud enough to drown out EVERYTHING.  The Z3's dBs dont go high enough at 100%
Lord_viridis
Not had a problem with volume myself, make sure dynamic normaliser is turned on.
SergioPL1
Contributor
Playing really loud for longer periods of time can be dangerous. Maybe you should try noise cancelling headphones? They cut environment better (but not everything to be honest).
Zaiaku
Visitor
The dynamic normalizer drops the volume further. So does clear auido..
Also, they are noise cancelling but when a 3 year old phone beats the new one hands down, somethings very wrong.
