touch screen problem
SOLVED
Nephilite
Visitor
I have recently started having a problem with the touch screen on my Xperia XZ.
On my home screen and within web pages and apps I seem to have a dead zone about 2 thirds of the way down my screen (I can neither press any links in that zone or drop any icons past it on the home screen) yet when i run the touch screen test within the support diagnostics it seems to be working perfectly so basically im stumped ..... I have done a factory reset but to no avail
My wits end is definitely within view
1 ACCEPTED SOLUTION
Accepted Solutions
dquilon
Contributor
Regarding the diagnostic test, it is NOT very accurate because it shows a thick drawing under your finger and you will not see dead zones... However if you go to the engineering menu: *#*#7378423#*#* and under service test, you will find the touch screen test that uses a fine line for drawing, that will allow you to see imperfections on the hardware better.
6 REPLIES 6
profile.country.PL.title
najodleglejszy
@Nephilite does the same thing happen in safe mode?
SR147
Visitor
I had the same issue. It's hardware related, and unfortunately for you your device will need to be sent away for repair.
Nephilite
Visitor
Yes it does ... its infuriating and baffling
Nephilite
Visitor
that seems to be the case although i dont understand how it can work perfectly within the diagnostics but not at any other time
dquilon
Contributor
Nephilite
Visitor
thank you
