Anyone using XZ Premium experienced this?
It happens occasionaly but it will be removed once the phone is restarted.
I am just curious, is this a sony defect, a bug, or a feature of Sony?
Solved! Go to Solution.
It's not a bug. This theme uses a transparent clock widget, means it will show the part of the wallpaper "below it" on your home screen. Maybe restarting your phone resets the position on the wallpaper so the visible area is unicolor. You can easily notice the effect if you slightly swipe your lock screen to the left without actually unlocking.
Tried it on and it worked. Thank you for the confirmation.
