Phone starts charging after a wiggle
My phone randmly stops charging and is charging very slow I'm using quick charge 3.0 I have to put the usb type c cable in a certain position to get my phone charging
Now phone isn't charging at all
Are you able to see if the USB-C port is damage? Or the pins in the phone and charger?
Yes I did inspect the port it seem fine and unharmed.
Have you tried with a different charger or cable?
If this doesn´t help, and you don´t notice any change, my recommendation is you to contact your local support team so they can assist you better and have your phone examined!
Please, tell me how it goes
Update that I just found a way to charge my phone when I put pressure on that particular part <shown in the picture> of the phone with both of my thumbs from front and back my phone seems to charge fine but I have to put a lot of pressure.
P.S I dont know much about the hardware stuff but I just found that way while messing around with my phone
