Since the latest upgradge on my XZ2 - I can nolonger maintain a pairing between my car and phone. Every minute it keeps droping and re-connecting. This does not happen on my Xz with v8
Frustrated of Wales
Maybe it has something to do with this problem: /t5/Xperia-XZ2/Bluetooth-stuttering-issues-with-the-codec-AAC/m-p/1370672#M3548
Just give it a try and manually set the Bluetooth-Audio-Codec to "SBC". Also you can play a bit with the AVCRP-Settings.
Thank you for the suggestion - it is not a problem whith the media connection just the telephony connection remaining stable. I did try your indicated link but same issue - looking at other forums this appears to have occured accross multiple manufacturers and phone types the only apparent comonality is they are all as a reult of upfrading to Android 9 PIE - My own exerience bears this out given my XZ which is on 8 still works fine.
