That mean that you are sending or receiving MMS, which they can only be sent/receive through data
I like your thinking but I never send or receive mms, and if that's the case it would only last a few mins not the whole time I leave the mobile data on.
Thanks for responding
All apps are closed yet it still does this. I can be streaming a move on WiFi yet the mobile data is flashing. I will try safe mode in morning g when I finish work.
Many thanks
Sounds to me like you have a weak signal on wifi and it's using data to fill on the gaps if you catch my drift. Is this happening when you are in direct line of sight of the router? I've had this issue before.
