on the sony docking station as well as third party magnetic chargers the phone shows charging symbol flashing on and off.
it does not change after hours and discharges when connected over night.
anyone has same issues or knows a remedy?
yt
jan
See if the same occurs in safe mode:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
same in safe mode.
actually it does charge if the phone is completly switched off as it seems.
will go to s/w repair next.
to catra: very helpful. thanks.
I am sorry,but a software repair does help many times.
software repair/computer does not even recognize the z2 when connected via usb....
So if you turn off the phone and connect to PC when prompted by sony update service it does not check the firmware?
well, i now did a full roll back and re setup.
when i switch off the phone it repeatedly shows the sony splash screen, swithes off, does the splash screen again. only stops when i press the little red button.
ps: when i connect usb holding the vol- button, phone does not start but only shows charging screen.
