Z2 Haptic Feedback weakens as battery drains.
ledjps
Visitor
Just bought my Z2 two days ago and just installedcthe latest update which will hopfully cure the following issue.
I have noticed that after fully charging my battery, the haptic feedback on home keys and when typing will work perfectly. It seems that as the battery drains, the haptic feedback will become weaker, almost as if power is not going to the motor. When the phone is then charged enough, the feeback will then work as normal.
What is causing this and does anyone else have this happening ?
4 REPLIES 4
hedrox87
Contributor
I've noticed something similar too, after .314 update sometimes typing messages seems laggy (swype lines showing up after 0,5 - 1 sec. after finger move which causes swype to mistake my words), however no apps running in background and eating memory, in my example it has nothing to do with battery status it sometimes laggs typing on 99 - 89% of battery left. 3 GB of RAM and they made the phone slow with updates... what a tallented programists Winking_Face Hope for some keyboard update to solve SWYPE lagging.
dm841
Contributor
If your device is slow after update will advice you backup and reset device to factory settings I've updated to the latest version and have no lag what so ever and I have 87 apps on my device
thequickbrownfo
Visitor
Did the latest update that came through yesterday and the haptic feedback has been lowered, making it virtually impossible to register any vibration at all. Will do a repair to see if it solves it Slightly_frowning_Face
thequickbrownfo
Visitor
Ok, ended up with my replacement which have not displayed any of the vibration issues as above. I can only assume that this was a hardware fault.
