XPERIA S/SL Image Compression/Noise reduction issue
ansark
Visitor
Hi Sony,
I have a few of questions regarding the poor quality of photographs taken from Xperia SL(or Xperia S)
1. The camera isn't bad, definitely, since it manages to take sharp pictures in daylight, but as the sun goes down, this same camera returns some really poor quality pics. Why is there such a huge difference in quality? The images are blurry, unfocussed and have a lot of artifacts.
2. Is this hardware or software related?
3. If software related (Image Compression/Noise reduction issue), should we be expecting a fix?
4 REPLIES 4
XperiaSadi007
Visitor
These Tips will improve the quality in low Light Conditions....
1. Use Multi Focus
2. In Low light, Turn OFF Scene Recognition, Do Everything Manually, Use Normal capture Mode....
3. Use LED Flash Light....
4. Use party Mode (in scenes)
5. Manually Slect Exposure value as suitable.
6. Use Camera Button not on screen button if images are blured, press lightly, when image is focused, press it fully...
ansark
Visitor
Thanks, I will try it out.
arronlee
Visitor
Hi, have you tried it out? I wonder whether you have found a good image compressor to help you with the image compression work? I am agreen hand on this field. Any good suggestion? Thanks in advance.
Best regards,
Arron
Thommo
Why are you going round posting in forums an answer that has already been said in threads over a year old in some cases 3 years old
