Xperia M-Dual (C2005) charging problem
ivlux
Visitor
i upgraded my phone to the newest android version released for it, since then the phone has not been charging normally. sometimes it does not charge at all even when it displays "charging", and after a few minutes the battery begins to drain even while it is connected to the charger.
I did not do the upgrade with my PC this time, i did from the phone(from the phone's update center) while it was charging.
The charging port is ok, so what could be the problem and how can i fix it?
thanks.
9 REPLIES 9
samkkr
Visitor
did u restart the phone once and try? do a phone once again then
Alexander1
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Have you tried to charge your phone with another charger?
If you still experience the same behavior I would suggest that you repair the phone software using PC Companion.
http://www.sonymobile.com/update
In PC Companion, press start on Support Zone > Start on Update the phone/tablet software > Press the blue link that says "Repair phone/tablet".
Before repairing the software in your device you may want to backup your information first. Check out this topic for more information on how to:
http://talk.sonymobile.com/t5/FAQ/Backup-amp-Transfer/m-p/407253#U407253
ivlux
Visitor
thanks Alexander,
i have tried different chargers, even with my laptop too, but it is the same thing. i have also done repair with sony update services succesfully, but it is still the same. what else can i do please.
ivlux
Visitor
yea Samkkr, done that.
thanks though. any more ideas?
ivlux
Visitor
hello Alexander, any ideas yet? i realy need to fix this problem.
"expecting your reply, Thanks
samkkr
Visitor
then would suggest to take it to a sony center
Alexander1
Champion
Just as suggested above, I would recommend that you have your phone examined by a service center. Please contact your local Xperia support team for more information:
http://www.sonymobile.com/global-en/support/contact-us/
ivlux
Visitor
thanks
samkkr
Visitor
keep us updated Winking_Face
