Xperia C4 camera problem
Taylor18
Visitor
Hello...
To start with...my Xperia c4 got memory card slot problem...memory card used to be detected by the mobile but it used to eject outside by itself.. i mean it doesn't fix into the slot.. So I took it to a nearby sony serive center and they've told me that they need to replace the whole motherboard to fix this prob..
So i gave my mobile and then memory card problem was solved..but my mobile IMEI number was changed as the motherboard was replaced and the phone became slow after this service. And the most problematicthing is that back camera isn't able to capture pictures clearly i mean the focus of the camera has completey became weak after the service..To explain this if i take photo of a document everything was to be blur and I couldn't understand a thing in it..
I have read somewhere in the net that to solve this problem i need to reinstall the software by Sony PC Companion..So i did..but still the problem didn't solved..
I wish someone can help me solve this problem..thanks inadvance Slightly_smiling_Face
1 REPLY 1
Uliwooly
@Taylor18
I'm sorry to hear that, you have to take it in so your Local support can inspect your device.
