Sony Xperia Z2 won't charge, reset or turn on
Wizy
Visitor
I've had Xperia Z2 for almost two months now, today when I was at work I noticed that it was off, although it had more than 40% of battery still remaining. I tried turning it back on but as it didn't work I figured something was wrong with it. I tried hard reset and it did vibrate three times, but it still wouldn't turn on. I thought something drained the battary and waited till I got home to charge it. Now that I am at home it doesn't even charge, none of the LED lights work, it won't connect to pc companion either and hard reset now does nothing (as in, it doesn't vibrate 3 times anymore).
I tried volume up/down+power button combination, hard reset, held the reset button for longer than 15 sec, I removed sd card and sim, nothing works the phone is just lifeless. I haven't dropped it or used it intensely, it  never overheat or anything of that sort. it was really babied.
Anything else that I should try before taking it to the centre?
3 REPLIES 3
Thommo
If you have tried a hard reset then you could try a system repair as seen below but other than that it is a case of either returning your device to the place of purchase or contacting Xperia care http://www.sonymobile.com/global-en/support/contact-us/
To performing a system repair - This will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
mcjez15
Visitor
what if the phone doesn't connect to PC or ca't be detected?because it can't be detected only a red light comes up when i connect to pc..
tumi7
Visitor
the exact same thing just happened to my phone yesterday. i do not want to do a factory reset. how did you solve the issue with your phone?
