Hello
I bought the Sony Xperia M2 Dual from Greece and I use it in Greece.
Trouble sending and receiving mms network Cosmote, tested both ports sim but the problem still after upgrade to 4.4 kitkat sim card change as changes in a variety of settings mms unfortunately the problem persists. In VODAFONE card work properly.
Even some hangs that harm came to the screen and not taking no touch command to upgrade the moment disappeared.
Also have sync problem with much faster memory cards.
Even after the upgrades do not allow me to choose to be open the data on both cards sim.
I expect the answer to SONY for the problem of mms.
I would like your own opinion on the above problems.
The upgrade is: 18.3.1.V.0.18 4.4.4kitkat is correct ???
thanks
G. Miliotis
I HAVE CHANGED NEW CARD Sim.
UNFORTUNATELY THE PROBLEM REMAINS.!!!!!!!!
You do NOT have to SCREAM, all uppercase = SCREAM
contact your carrier and make sure that you have the correct APN settings
