I've recently upgraded to Lollipop Singapore Customized Generic (version 18.6.A.0.182) thru XperiFirm and FlashTool. I'm from Malaysia, the reason why i chose Singapore Generic is because there isn't any Malaysian Generic for version 18.6.A.0.182. And my questions are :-
1. Does this affect the mobile signal ? (Maybe because it is customized for Singaporean telecommunication networks or something)
2. Is it normal for AndroidOS and Cell Standby to drain up so much battery? (I've set Stamina mode when battery starts to drop below 75%) (Pics of my power management graph below) (I did a factory reset, when I first upgraded to vesion 18.6.A.0.182)
3. What is the usual/ common Signal strength for phones (not 4G) ?
Thanks in advance !!
You might want to repair the phone with PCC, it will smooth things out, as affecting network signal it shouldn't but if it does, flash back to the original firmware then flash again but exclude the baseband.
as for the common signal strength its not phone related but how good your network coverage is.
Hi, thanks for the reply. I've tried doing the PCC repair, theres not much improvement, but one thing i noticed is, I offed the Battery Stamina mode, the battery doesnt drains so quickly
*I dont know why this happens but yeah, i turned off Stamina mode*
Besides that, my AndroidOS is still consuming much of the battery, but there's a significant drop (i guess), is this normal ?
